Author Topic: Synchronous motors questions  (Read 2567 times)
Offline GoatZeroTopic starter
« on: October 16, 2013, 08:12:37 pm »
 i have been reading about synchronous motors, and i actually got one from a microwave , i was playing around with it and suddenly when i was spinning the propeller i got shocked, by touching the terminals
i pulled out a multimetter to meassure voltage in CD and CA and both are getting generated, (way more CA than CD)
so now i wonder
Why is this happening?
Is it generating AC or DC ?
Whats the max voltage i can get from spining this thing ?
I have to go out i will plug it to an oscilloscope later tonight however i wanted to ask so maybe someone gere can give me any leads of why is this happening
« Last Edit: October 17, 2013, 03:00:10 am by GoatZero »
Offline peter.mitchell
Re: Synchronous motors questions
« Reply #1 on: October 17, 2013, 04:52:50 am »
it's a 120v motor rated for 6 rpm.
it will generate AC, at a pretty high voltage, put your multimeter on it in ac, stick it in a vice/vise and SLOWLY spin the shaft with your hand, and then with a drill to see what kind of voltage you get, you might be surprised.
Offline sleemanj
  • Professional tightwad.
« Reply #2 on: October 17, 2013, 05:43:37 am »
Ask yourself the question"what is the difference between a motor and a generator".
Offline amyk
« Reply #3 on: October 17, 2013, 10:54:28 am »
I wouldn't advise the latter - this looks like a geared motor with a very high reduction ratio (designed for 6RPM out) and pushing it much beyond that has a high chance of breaking something.
Online Zero999
  • 0999
« Reply #4 on: October 17, 2013, 12:41:09 pm »
That's exactly why he said slowly.
It's not only the gears which could be a problem, if you spin it too quickly, the output voltage could be too high for the insulation, causing it to arc over.
« Reply #5 on: October 17, 2013, 06:46:10 pm »
As it is a synchronous motor it has a permanent magnet on a shaft. Turn the magnet and you make a changing magnetic field in a coil of wire, which generates a voltage. Slightly different construction is used to make an alternator like in your portable genset, but the principles are the same.
