Author Topic: How to physically connect AS3933 to 3D antenna?  (Read 781 times)
Offline filthyfrankTopic starter
« on: June 13, 2019, 04:53:26 pm »
I’m trying to breadboard LF frequency receiver circuit using AS3933 (https://www.digikey.se/product-detail/sv/ams/AS3933-BTST/AS3933-BTSTCT-ND/3028676) receiver chip IC and CAS143-147 3D antenna chip (https://www.digikey.se/product-detail/sv/sumida-america-components-inc/CAS143-47/308-2270-1-ND/4356340). However I don’t understand how can I connect AS3933 pins to CAS143 on a breadboard. CAS143 seems to be a SMD chip and it has some weird spacing between it's pins (see image attached) so I can't use standard TSSOP/SOIC to DIP adapters. Does anyone has any suggestions about connecting those two?
