The
PSU has a nominal input current of 0.15A and has a peak inrush current of 40A. No info about how long the inrush current lasts is given.
The ballast has a nominal current rating of 1.5A with a max peak inrush current of 21A lasting for 185 microseconds.
After reading the Little Fuse's
guide, I got some info on how to account for these inrush currents while selecting a fuse. I do not have an idea about the waveform of the inrush current so went with the waveform that will give me the maximum i2t value from chart 1 in the guide.
For 100,000 cycles I get a i2t value of 0.185. So a 2A fuse with a i2t value greater than 0.185 should be used as F1, am I right? How do I calculate i2t for F2 where I don't the time period of inrush current? The F3 is to protect the micro and 7 seg display? Will a fast blow 1.5A fuse be a right choice? Cos I don't have both inrush current or timeperiod to calculate the i2t.
Also, I need a fuse as soon as the mains enter, will a 3A fuse with the greater i2t value(F1) be a right choice?
Thanks
