I'm sure this is a question that's asked frequently, so I googled as many documents as I could before asking and actually came out with more questions than I started with (I'll link the documents below).
I'll start with where in the circuit I think it's needed and why: I have a 12V DC input to the circuit with multiple possible connectors. The "default" is a 5.5mm barrel connector, but there will likely be other ways to hook up to it, possibly an XT60 connector or even screw terminals.
The "loose wire" scenario is likely -- I can't know for certain which end of the wire will be connected first, so I could grab a cable that's been gathering static with nowhere to unload it and plugging it into the circuit. The first component in the circuit is a reverse-mounted N-channel MOSFET to prevent reverse-polarity connections, so the gate of that MOSFET could be fried by an ESD, which is what I'm trying to prevent with a TVS diode.
My first question would be -- is the scenario that I'm trying to prevent (the MOSFET's gate getting zapped) something that a TVS diode would solve, or should I be doing something else?
Additional questions:
If I'm only trying to prevent ESDs, what kind of wattage am I looking for? How do I estimate the wattage of a potential ESD?
Is there any reason not to get a bidirectional TVS?
Are TVS diodes also the part to use if I'm trying to prevent small voltage spikes (noise from the power supply), or should I be looking for a different solution in that case?
Here are the documents I've been looking at:
http://www.completepowerelectronics.com/tvs-diode-selection-tutorial/https://www.ttieurope.com/docs/IO/15325/TTI_TVS_Diodes_Selector_Guide.pdfhttp://www.powerelectronics.com/regulators/selecting-protection-devices-tvs-diodes-vs-metal-oxide-varistorshttps://www.microsemi.com/document-portal/doc_view/14650-how-to-select-a-transient-voltage-suppressor
