Anyway, is there any particular reason why you'd want to build one of these? They are very simple, and there should be dozens of comparable Z80 single board computer designs kicking around on the Internet.
From memory it was a simple oscillator (either using inverters or a transistor multivibrator), a 2732 EPROM, and 74LS374 latches for I/Os. The Tek-1 also used a 74LS138 to decode ports - the Microcomp might not have bothered with the latter for simplicity.
