So I googled how to measure hFE using two ammeters and this thread came up: https://www.eevblog.com/forum/testgear/measuring-hfe-of-a-transistor-by-multimeter/ - OK, seems simple enough:
hFE=154, seams reasonable for BC547. Then I got briliant idea to replace the transistor with short and the result:
hFE=144, that's really good for piece of wire. Before I head to the patent office, are there any better methods at measuring hFE?
Not sure if anyone mentioned this yet, but the circuit with resistors means almost nothing except that if you had a transistor that acted more like resistors then you would get a false reading. Another example is when you measure the resistance of a diode. If the diode measures 100 Ohms, does that mean it's now a resistor. Certainly not, it only looks like that for one particular test current. If we vary the current we find that it does not work like a regular, fixed resistor.
In short, a transistor is not a set of resistors it is much more dynamic than that. When you replace the transistor with resistors you are no longer measuring the Beta you are measuring the currents into a three resistor network.
What this means is when a transistor goes bad its Beta is usually going to go off the charts. For example, a transistor that normally measures 100 will measure 10 or even lower when bad. That's one of the assumptions of this test.
In reality the transistor needs to be tested at several operating currents anyway. That means the input current has to be stepped from say maybe 100ua to 1ma to 10ma, and read the output current. The point where it enters saturation is also a good test, as well as the saturation voltage with different collector current levels.
The best test is to vary the input current from some low value like 10ua up to maybe 10ma (depending on the transistor) and measure the Beta spread. The Beta will change wildly with different input currents. A transistor that measures 100 will often measure just 10 when near saturation because the collector base diode becomes a little forward biased and therefore 'steals' some of the current from the base, meaning the external base current has to be higher than usual.
When we use simple, basic tests like this, we always have to live with some assumptions. If we are not willing to do that, then we have to move on to a much more sophisticated test or set of tests. The simpler tests work in most cases and are designed to be simple and fast.
If you really want to test a transistor completely, you've got a very long way to go. Even an automatic curve tracer isn't going to tell you everything. There are many, many more specifications that have to be tested.
