I'm pretty new to this.
I have a voice recorder with a 3.7v 850mah lithium ion battery. I'd like to solder in an upgraded replacement that has a capacity of 2000mah (also 3.7v).
Afterwards when I plug it in to charge, will it charge the new battery to full, or do similar such devices typically include something that governs/limits the amount of charge to that of the original installed [850mah] battery (i.e. programming in the ic, for example, etc)?
