Its always puzzled me how some component leads can carry the current the of that device. One that gets me are transistors, be it TO22 or TO3P TO3 etc. I read maximum ratings and see for a few Amps maybe low tens of Amps it looks up to the job.
But when you talk of transistor collector currents above, say 15 Amps, and as much as 50 Amps i wander why the component leads are not thicker or heavier duty.
Same on many other components. Just puzzled me. Two devices looking the same, one can handle 15 Amps, the other in the same package can handle 50 Amps. Yet the component leads are the same gauge for both. Same with other components in high current senarios.
Your input cables are massive, your output cables are equally as heavy duty, but the gauge of your high current component leads look whimpy in comparison. Anyone know why manufacturers don't make there device leads more heavy duty ? The devices still work supplying the currents needed with out bother, but they seem flimsy in comparison to the wiring needed to carry these heavy currents..
