Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How to reinforce this through hole joint with a ripped pad?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to reinforce this through hole joint with a ripped pad? (Read 513 times)
artvandalai
Regular Contributor
Country:
on:
March 04, 2025, 12:40:35 am »
I ripped off this trace trying to solder this pin back. Any advice on how to reinforce this pin that has alot of mechanical stress to the through hole when the trace has been ripped off?
Last Edit: March 04, 2025, 03:51:32 am by artvandalai
Logged
Jwillis
Super Contributor
Country:
Re: How to reinforce this through hole joint with a ripped pad?
Reply #1 on:
March 04, 2025, 03:12:31 am »
Copper or Bronze PCB Rivets. You can get them from .8mm to 5mm inside diameter.
Logged
wraper
Supporter
Country:
Reply #2 on:
March 04, 2025, 03:32:31 am »
Do not bother with the pad, use neutral silicone adhesive to hold the part in place instead.
Logged
inse
Super Contributor
Country:
Reply #3 on:
March 04, 2025, 06:04:46 am »
When you pull or push the connector, the pin will come loose again, silicone won‘t hold it back.
Stabilize the pin on both sides with good epoxy glue e.g. JB Weld
Logged
artvandalai
Regular Contributor
Country:
Reply #4 on:
March 04, 2025, 06:14:21 am »
Will uv glue work or use epoxy instead?
Logged
benj38
Frequent Contributor
Country:
Reply #5 on:
March 04, 2025, 08:17:00 am »
Epoxy is better in this application, but UV glue should also work.
Use a jumper wire soldered on one end to the pin, and the other end to another component pad on this PCB trace that was lifted. The wire will serve as a flexible backup to the trace, so even if things move, the pin will still be electrically well connected.
Last Edit: March 05, 2025, 04:55:30 pm by benj38
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
