Hi nice tutorial.
Just to satisfy my curiosity.
What is the board in the example used for ?
Thanks to share your knowleges with us
It's used on a ancient inversor to generate a square wave, actually is a pretty bad design (not mine).
Thanks for the tip. I've installed GIMP and tried it. But I'am again stuck in point 7 of tutorial:
7. "The 2 images are not in the same size, or angle. So we will use the Distortion tool to resize and straighten the corners of the top side so it match the bottom side"
Tools -> Transform tools -> pick your tool
No need to do everything by the book, I here by give you the right to improvise.
I'm not familiar with GIMP but I'm pretty sure it can be done.
as I said on the first post, some things will be slightly different on other softwares.
"The adjustments are subjective and will depend on your board color, illumination, exposure, etc... there are many variables, play around and find what values works best for you."
