Hi guys,
Quick question.. how do charging batteries work? Whether it be single batteries like AA, AAA, C, D etc.. or a phone / electronic device or even a car battery, what's the requirements in order to charge them? Do the input voltage from the charger have to match the voltage of the battery your charging.. ie.. 12v car battery, do I have to use a 12v charger.. or can I use a lower voltage, say 6v .. or even a slightly higher voltage..say 14v?
What about charger source?.. can the source be from anything that outputs voltage.. like a power supply from another device ? If so, what the the Pros / cons of it?
Does the current output from the charger matter? or does that just determine how quickly it will charge?
Do the batteries determine how much Amps are drawn from the source.. like an electrical device?
Sorry for the odd random Question, though just thought I'd ask
Regards,
