Author Topic: HOW TO SENSE 12 VOLT DC VOLTAGE USING MICROCONTROLLER?  (Read 6557 times)
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
Re: HOW TO SENSE 12 VOLT DC VOLTAGE USING MICROCONTROLLER?
« Reply #25 on: July 06, 2018, 04:40:47 pm »
Yup,its a cultural thing.
People don't play attention to the important parts otherwise.
It's origin? our schooling system I guess.
The textbooks are huge but the parts students are supposed to learn are one or two lines per page,made to underline by our teachers. I still used to read the whole book
« Last Edit: July 06, 2018, 04:52:10 pm by Raj »
Offline Raj
  • Country: in
« Reply #26 on: July 06, 2018, 05:25:04 pm »
Raj n Kumar, why Indians love to use eyes blinding text all the time ? Not only you two, but I have seen too many at various forums as well.
Is it a cultural thing ? As common netiquette, its like shouting out loud when talking, everytime.  :-//
Perhaps their love of eye burning text is linked to their taste for mouth burning spicy food?
Anyway, I recently posted this schematic in another thread. It converts a voltage ranging from 10V to 15V to 0V to 5V, which can be read from an MCU ADC pin.
https://www.eevblog.com/forum/projects/mesuring-a-12v-lead-acid-battery/msg1644677/#msg1644677
Interesting...I would have taken a way expensive route with negative voltage or ground isolation from input,making input ground, -10+diode drop equalvant and a diode at input,
or simply use 16 bit mode adc ( there's an article on microchip's website on how to do that on 10 but atmegas without external adc)
« Last Edit: July 06, 2018, 05:31:46 pm by Raj »
Offline Raj
  • Country: in
« Reply #27 on: July 08, 2018, 09:46:29 am »
Hey orignal post author,
If I am guessing correctly,I think you are trying to make a car voltmeter or a battery monitor of some sort,right?
Offline wabhavkumarTopic starter
  • Country: in
« Reply #28 on: September 29, 2018, 11:46:55 am »
Hello all,
can anyone suggest, below attached circuit diagram can work or not?
if not, please suugest pc817 optocoupler circuit for sensing 12 volt using microcontoller.
Offline Raj
  • Country: in
« Reply #29 on: September 29, 2018, 02:07:41 pm »
This will work
  • Country: in
« Reply #30 on: September 29, 2018, 04:32:24 pm »
this circuit is not working at 50 meters circuit
Offline Mr. Scram
  • Display aficionado
« Reply #31 on: September 29, 2018, 04:49:31 pm »
thank you for the valuable reply. Please suggest optocoupler circuit.
What's wrong with a voltage divider? It seems by far the simplest solution. Without more information we're left guessing.
Offline Zero999
  • 0999
« Reply #32 on: September 29, 2018, 06:50:35 pm »
What do you mean by 50 meters circuit? It makes no sense.
Is this connected to circuit, via a long piece of cable? If so, then you should have said before!
Offline Kjelt
« Reply #33 on: September 29, 2018, 09:19:47 pm »
At 50 metres you should put a microcontroller on both ends and connect with rs422/485 or ethernet
Offline Mr. Scram
« Reply #34 on: September 29, 2018, 09:23:13 pm »
This community seems so eager to help that it often starts offering advice before someone has bothered to properly specify the problem. That doesn't foster proper behaviour.
Offline SparkyFX
« Reply #35 on: September 29, 2018, 09:43:32 pm »
I don“t see why that reed switch should not operate at the microcontrollers operating voltage. Or switch ground with a pull up?
Support your local planet.
  • Country: in
« Reply #36 on: September 30, 2018, 11:00:50 am »
I am really sorry for posting an incomplete question.
yes, if no/nc switch is connected with 50m length of wire, then this circuit is not working properly.
Can anyone suggest some better circuit?
Offline Raj
  • Country: in
« Reply #37 on: September 30, 2018, 01:41:00 pm »
go see Reply #20 on: 06-07-2018, 18:21:35
Use it.
