https://www.eevblog.com/forum/beginners/how-to-set-reference-for-a-sine-wave-with-dc-supply/?action=dlattach;attach=459484In the above you is your AC Switch where you use SCR's, This is my #1. The doted box part is removed.
This is the power switch to Spot Weld Power. ( state #3 in below list)
You have a microwave oven transformer.
guess
Rated for a Primary voltage of 240V
Secondary of 30VAC peak to peak with nothing connected.
A large transformer, could be rated for over 1000 Watts.
Would be nice to know the transformer primary resistance(impedance) with nothing connected to secondary( transformer's idle current).
You want to sense a contact change.
This is a resistance change to V= I x R.
This requires a power source to supply V & I.
A sensor that detects a change in V or I,
To sense this you need a second point of change that prevents short circuit current.
Now to be clear, here are the states I see for the secondary of transformer.
1. OFF no power.
2. With Contact sense Power.
2a. Open contacts
2b. contacts shorted
3. With Spot weld Power.
3a. Open contacts
3b. contacts shorted.
Note that a & b are limits of a large resistance change range.
You should note that with #3 you have very high currents & No current states. At these current levels just wire will act like an inductor. You could have large voltage changes from inductive kick.
So #3b above is a nasty state that wants to destroy things. Here the max current is only limited by transformer. The transformer is not operating as designed.
Now think about #3 above Spot weld power to secondary.
You have #3a where you have transformer idle current.
You have #3b where you nave more current then transformer is rated to handle.
There is a huge current change between these two states.
In the above list, State #2 needs protection from state #3
There are many ways to create power for #2 above.
My R2 is part of a AC based Ohm meter with line power source.
You have a voltage divider composed of R2 & transformer primary winding. It is using the bidirectional nature of a transformer.
Line voltage is the #2 power source with R2 supplying the Current limit.
This voltage divider lets you sense a spot weld contact resistance on secondary. The transformer is actually providing some protection to this voltage divider from the nasty secondary side.
With R2 being part of voltage divider, it is also setting the spot weld contacts open circuit voltage.
so #2a is open circuit secondary voltage R2 creates by supplying power to transformer primary.
#2b is short circuit secondary current limited by R2.
Now run some values for R2
If R2 = idle current of transformer primary you have.
1/2 line voltage across R2 & primary.
Secondary voltage = 1/2 of when powered by line. If Line gives a 30 volt P-P then secondary is 15 volt P-P when open circuit.
The ratio of R2 & primary changes as resistance across spot weld contacts decreases to a point where you have min voltage across primary and max voltage across R2.
You are working with ratios.
The ratio of R2 resistance and Transformer resistance.
#2a is R2 and idle current(secondary open)
#2b is R2 and primary resistance with secondary shorted.
You have a voltage sense that detects change from open to desired contact resistance.
In
You have a AC voltage sense circuit composed of R1 & SFH6206 parts.
This will detect very low levels of AC. The R1 resistor is protecting the SFH6206 from over current, but also setting the turn-on voltage of SFH6206. Increasing value of R1 will increase turn-on voltage.
Output of SFH6206 will be in form of pulse as AC input voltage changes above or below the turn-on voltage for each half cycle of line..
In addition to adjusting R1, you could connect one input to a line power voltage divider to adjust turn-on. The AC voltage sense would then be between voltage divider and junction of R2 & primary winding.
Need to keep in mind that when secondary is shorted, you could have full line voltage across R2 so the wattage rating of R2 needs to handle this.
In the past I worked with a circuit that had a power button shorting the secondary of a transformer. The primary of transformer was in series with a relay. The power button would cause the relay to change to energized state. With the power button open, the relay would not energize. This change allowed a Line voltage relay to be used instead of a low voltage relay connected to secondary.
