As it happens I'm in the middle of working on one of these at present. Don't worry if you can't answer all my questions, just do your best.
Please point to the exact schematic you are using along with component values, diode types, etc. Be as specific as possible about the inductor, as that's a very core part of all such circuits - eg. is it purchased, scavenged, homemade? Have you confirmed the value? Any idea what the saturation current of it is?
Double check that pin 4 is _not_ connected to ground, as that's a rather important part of the inverting configuration (although if you're getting -8V out this is highly unlikely).
Do you have access to an oscilloscope? If so, screenshot/photograph and post the following measurements: pin 2 referenced to ground (switch output), pin 3 referenced to pin 4 (timing capacitor), and pin 6 referenced to pin 7 (voltage across current sense resistor).
