the problems were with one of solenoid cores
I would expect to read more practical approaches, about the specific problem.
That is a solenoid core who operates at 12V or 24V, and needs almost 1A ampere so to arm it self.
One primitive and brave electrician
, he would replace the solenoid in a such of a problem,
and if this had no effect, he would replace the cable.
There is no actual need to ever test a cable for broken strands.
It is the fate of the control cables to die eventually due the stress conditions that they face.
Another example of where such control cables gets stressed at it max, are in the control boxes of huge movable cranes inside of a factory.
The worker gets the control box of the movable crane at hand ( the cable is 8-9 meters long and is connected with an crane of 11 meters high),
The in-door crane moves on metal rails that are on the side wall of the large building.
In order to protect those control cables from the adequate pulling, that causes the distraction of them, we use " steel wire " that connects the crane with the portable control box, in parallel with the control cable, so to be stressed the " steel wire " instead of the control cable.
The steel wire haves the tendency to extend it length, and need few readjustments until to stabilize.
No one does those fine adjustments, the workers usually do not report anything at the maintenance department until something really stops working, and eventually the control cable stays unprotected, and dies.
In the last factory that I was working, he had 14 of those .
