Author Topic: Soldering Iron Station VS Hot Air Rework Station  (Read 17403 times)
Offline DevianTopic starter
« on: November 16, 2011, 03:58:22 am »
Soldering Iron Station VS Hot Air Rework soldering Station? You will choose which type?Why?
Offline IanB
Re: Soldering Iron Station VS Hot Air Rework Station
« Reply #1 on: November 16, 2011, 04:23:55 am »
I will choose the soldering iron station because I don't do any SMT work. Which one will you choose?
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: November 16, 2011, 11:38:37 am »
If you need to own only one, its a soldering station.  However, until Dave reviewed the compact, no-nonsense, cheapo hot air workstation by 858D Atten, I didn't think I needed it.  With the 858D I find its easier to reclaim parts and working with SMT much easier.
Best Wishes,
 Saturation
« Reply #3 on: November 18, 2011, 03:01:09 am »
Thank you guys, that is to say, hot air rework station can do much more rework than soldering iron station? but soldering iron rework station also have many kinds of soldering iron tips, there still many smt rework it can not do?
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #4 on: November 18, 2011, 03:11:40 am »
+1  Same here,  I find it very usefull for many things.  I was able to replace some thru hole hall effect sensors on brushless motor sensor boards without removing the boards from the windings. Just warmed the board and hall with the  smallest tip untill I could pull it out with hemostats and fluxed and installed the new one while the board was still warm.
The 858D I got only needed the case ground mod. the rest of it was ok.
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #5 on: November 18, 2011, 08:20:28 am »
I dont see the point here? Any of them is a separate tool and in electronics you will need eventually both (more soldering iron than air soldering station). They are pretty different things.
Oh, the joy of sending various electronics to silicon heaven
« Reply #6 on: November 21, 2011, 02:57:29 am »
Hello,thank you,guys
My problem arealy resolved
Regards
