Author Topic: How Can I check Horizontal output transistor with lcr-t4 meter?  (Read 786 times)
Offline bshi02Topic starter
  • Country: kr
I checked Horizontal output transistor with LCR-t4 meter which has been desoldered from pcb of CRT TV and It was written "C6090" on its surface.
But Whenever I checked this HOT with lcr-t4 meter, it always displayed capacitor result instead of NPN transistor.
I also checked spare AOD412 MOSFET with LCR-t4 meter and It displayed correct result.
Is it impossible to check HOT(C6090) with LCR-t4 meter?
And I followed below guide which shows how to test Horizontal transistor with analouge meter.
I found that when I placed red probe to # pin2(collector) and placed black probe to pin3(emitter), Indicating needle won't move at all in x10 ohm mode.
Is this HOT IC(C6090) defective and Should I purchase it in order to fix symptom of staying in Standby Non-Operaiton?
« Last Edit: April 30, 2024, 11:08:55 am by bshi02 »
Offline xvr
  • Country: ie
    • LinkedIn
Re: How Can I check Horizontal output transistor with lcr-t4 meter?
« Reply #1 on: April 30, 2024, 05:52:58 pm »
Try pins 1 & 3 - it should be detected as diode with ~1.5V drop.
Offline wasedadoc
« Reply #2 on: April 30, 2024, 07:28:06 pm »
It's dead.
  • Country: kr
« Reply #3 on: May 01, 2024, 12:54:35 am »
I set DMM to diode mode and I placed red probe on #1 pin(base) and placed black probe on #3 pin(emitter)and placed red and black probe vice versa.
It get each reading of 0.523V and .0L V
Is it means that this HOT(C6090) IC has been dead?
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #4 on: May 01, 2024, 08:01:54 am »
No. Base junction is alive.
  • Country: kr
« Reply #5 on: May 01, 2024, 08:24:03 am »
But I checked #pin2,3(collector,emitter) of this HOT IC(C6090) with diode mode.
I placed black probe of DMM to #pin2 (collector) of this HOT IC(C6090) and placed red probe of DMM to #pin3(emitter)
and I also placed black and red probe vice versa.
BUT,It displayed 0L. (V) in all of diode voltage test between #pin2 and #pin 3(collector,emitter)
Is this result means HOT IC(C6090) defective?
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #6 on: May 01, 2024, 08:28:43 am »
CE should not behave as diode. So it mean nothing. In theory it should be detected as transistor by your tester, but it is a high voltage transistor so detection could fail, I can't say for sure.
  • Country: kr
« Reply #7 on: May 01, 2024, 09:55:08 am »
I read A ebook of CRT TV Repair ,It said that "when testing H.O.T, Most have in built internal diode between collector and emitter. Therefore if you measure between these legs you will get high and low."
So I think that It should get reading of some voltage and 0 voltage when I measure voltage between collector and emitter of H.O.T on diode mode.
I quote below guide from  ebook of CRT TV Repair
Little tip on how to test transistor
Tesing NPN transistor
testing between base and collector expect high and low on your meter on diode test.
testing between the base and emitter expect again high and low on your meter on diode test.
Testing collector and emitter expect high both ways.
Testing NPN transistor again use the same principle.
Use this rule when measuring the switching transistor(S.O.T) but when testing H.O.T please note that Most have in built internal diode between collector and emitter. Therefore if you measure between these legs you will get high and low.
Online vk6zgo
« Reply #8 on: May 01, 2024, 11:43:59 am »
Test between C & E with the DMM in "diode" position. using the red DMM lead for C, & the black one for E on an NPN transistor.
Reverse the connections for a PNP  transistor.
Initially, it will be an infinity reading, or something else weird, indicating a very high resistance.
Spit on your finger & use it to connect B & C.
If the transistor is functional it should turn on, giving you a reading.
If it has very little effect, don't give up, as power O/P transistors don't always have a lot of gain, & a "spitty" finger might be too high in resistance to bias the transistor, on so use a 4700 \$\Omega\$ resistor instead of the finger.
If you use an analog multimeter, note that most of them have reversed polarity on the Ohms ranges, compared to a DMM.
Your transistor is almost certainly a 2SC 6090 , which definitely is an NPN transistor, used in the horizontal output stages of analog TVs.
« Last Edit: May 01, 2024, 11:47:38 am by vk6zgo »
Online vk6zgo
« Reply #9 on: May 01, 2024, 11:46:52 am »
"e-books" often lead folk astray--- change "most" for "sometimes" & you will be closer to it!
Offline wasedadoc
« Reply #10 on: May 01, 2024, 12:19:46 pm »
1. Datasheet for 2SC6090 has no mention of any collector-emitter diode.
2. Is the diode range on your meter able to light a red LED?  If yes, see if the transistor's base-emitter appears to be a diode and if the base-collector appears to be a diode.  Unless both appear to be diodes the transistor is dead.
« Last Edit: May 01, 2024, 12:24:40 pm by wasedadoc »
  • Country: kr
« Reply #11 on: May 01, 2024, 12:37:43 pm »
I followed your instructions(set DMM to "diode" position. using the red DMM lead for C, & the black one for E. then put some water on one of my finger ,and placed it to pin of Base & Collector.)
And I found that It displayed 3.290-3.250V in DMM.
But I stumbled onto below youtube video which demonstrated How to check  transistor horizontal c6090 with analogue meter.
It seem that He use YX-360TRD analogue meter for checking c6090 and set it to x10 ohm.And I clearly saw that Around 1:25, this YX-360TRD meter displayed low ohm when He placed red probe to #2 pin of collector and placed black probe to #3 pin of emitter which is not able to do with c6090 IC currently I have.
« Last Edit: May 01, 2024, 12:46:59 pm by bshi02 »
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #12 on: May 01, 2024, 01:04:02 pm »
Analog meter and DMM are quite different things when it comes to meter resistance of sonethig, that much more nonlinear than plain resistor. And transistor (especially high voltage) definitely not a simple resistor. So experience with analog meter could be not relevant to DMM one
Offline coromonadalix
« Reply #13 on: May 01, 2024, 01:25:20 pm »
same tought here
part testers can be good,  but when you deal with high voltage part(s)  the junction voltages can play tricks
high voltage diode too
analogue meter even if they measure voltages don't have the same working principle than new dmm, their impedance too are not the same
that's why some people doe dielectric tests with analogue meter instead of digital ones ...
for theses high voltage transistors i search the datasheet  (for the emitter collector diode who play tricks) i use diode tests and ohms tests
Offline madires
  • A qualified hobbyist ;)
« Reply #14 on: May 01, 2024, 01:36:08 pm »
The T4 Transistortester clone should be able to check that BJT. If it has a genuine ATmega you can flash a current OSHW frimware (k or m) to improve component detection and to also get more features.
BTW, detection of a BU508 (similar HOT) works fine.
« Last Edit: May 01, 2024, 01:40:12 pm by madires »
Online vk6zgo
« Reply #15 on: May 02, 2024, 02:05:44 am »
Analog meters typically use higher test voltages on the resistance ranges than DMMs & are capable of turning transistor junctions on.
In normal probing of circuitry, this is a disadvantage, so the DMMs are designed to not turn them on, by using a lower test voltages.
This necessitates a special "diode test" setting on the DMM (sometimes combined with the "continuity" function, as with my Fluke 77.
The "spitty finger" trick always works, except as previously noted, when the device is a bit lacking in gain, as can happen with power devices.
In that instance, a more formal biasing resistor does the trick.
Online vk6zgo
« Reply #16 on: May 02, 2024, 02:54:46 am »
What did it read, without the finger between base & collector?
It should be close to an open circuit
As a double check, just go back & check between base & collector, then base & emitter on the Ohms range--- it should be close to an open circuit in each case.
Now, using the diode mode , check between the same points (with the red DMM lead on the base) ---you should see a turned on junction in each case.
As to the video, unfortunately I don't understand Indonesian, so his commentary is lost on me, & I think I would find it essential to follow the action, as he moves a bit too fast for me.
  • Country: kr
« Reply #17 on: May 02, 2024, 02:01:02 pm »
I checked #pin2,3(collector,emitter) of this HOT IC(C6090) without the finger between #pin1(base) & #pin2(collector) in diode mode
I checked between #pin1(base) & #pin2(collector), with DMM on the Ohms range
It displayed 1.03M ohm and 66.5M ohm
and I checked between #pin1(base) & #pin3(emitter), with DMM on the Ohms range
It displayed 1.04M ohm and 68.5M ohm
I check between the same points on diode mode
When I placed the red DMM lead on the #pin1(base) and placed black DMM lead on #pin2(collector)
,It displayed 0.491V
When I placed the red DMM lead on the #pin1(base) and placed black DMM lead on #pin3(emitter)
,It displayed 0.522V
Although,I also unable to understand Indonesian,BUt It is possible to auto-translate indonesian subtitle to english subtitle in youtube setting menu.
I also followed this youtube video tutorial and I found that when I mesaure resistance between #pin2 and #pin3 with analogue meter on x10 ohm range, Indicating needle won't move at all in x10 ohm range.
But in this youtube video  analogue meter displayed low ohm when He placed red probe to #2 pin (collector) and placed black probe to #3 pin(emitter) around 1:25.
« Last Edit: May 02, 2024, 02:15:57 pm by bshi02 »
