Author Topic: how to test IR2108 MOSFET driver  (Read 3910 times)
Offline hussamaldeanTopic starter
  • Country: iq
« on: July 29, 2018, 09:14:25 am »
Hi all
is there a way to check if the IC work or not ?
because when I apply 12V to the IC and 5V to HIN and inverter one to LIN the output remains high for both mosfet
this is the circuit from datasheet
I used normal rectifier diode, 22uF 50V capacitor between Vb and Vs and 100Ohm resistor for the gate of the MOSFET
please help
regards
Offline Andy Watson
Re: how to test IR2108 MOSFET driver
« Reply #1 on: July 29, 2018, 02:11:14 pm »
How are you measuring HO ? Remember that this output is relative to VS. Also, to properly function, the LO mosfet must conduct for a period such that the capacitor between Vb and Vs is charged.
  • Country: iq
« Reply #2 on: July 29, 2018, 06:02:32 pm »
the pin and the ground using oscilloscope
I tried the gate of the mosfet and same result
Offline alsetalokin4017
« Reply #3 on: July 29, 2018, 06:46:12 pm »
The "LIN" is an inverting input, right, indicated by the line above the letters?
  • Country: iq
« Reply #4 on: July 29, 2018, 06:56:45 pm »
I used NAND gate to get the invert state (my NOT gate is burnt) and still no hope to get the output
« Reply #5 on: July 29, 2018, 07:17:23 pm »
OK, let's back up a moment. Forget about the NAND and inverting your input. What happens when you simply apply the +5V signal to _both_ control inputs at the same time? This should produce HO high level and LO low level.
And if you connect both inputs to COM (ground) you should see HO go low and LO go high.
« Last Edit: July 29, 2018, 07:27:10 pm by alsetalokin4017 »
« Reply #6 on: July 29, 2018, 07:26:01 pm »
Not ground, measure HO output relative to VS ! Which may or may not be at the same level as COM (ground). Measure LO output relative to COM (ground).
« Last Edit: July 29, 2018, 07:29:23 pm by alsetalokin4017 »
  • Country: iq
« Reply #7 on: July 30, 2018, 07:05:55 am »
well, I will test it back when I get back from the vacation and I will update you
