Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
how to understand the functionality of circuit
« previous
next »
Print
Search
Pages:
Prev
1
2
3
All
Go Down
Author
Topic: how to understand the functionality of circuit (Read 4574 times)
audio
Regular Contributor
Country:
Re: how to understand the functionality of circuit
Reply #50 on:
February 06, 2022, 08:27:48 am »
Sir,
Is there any way to include current limit indicator circuit. PFA.
Logged
xavier60
Super Contributor
Country:
Reply #51 on:
February 06, 2022, 11:05:45 am »
One way is to use another BJT to sense the voltage between pins 2 and 3 with a resistor in series with the Base. The best resistor value might need to be found by testing. A 1K to start with.
The indication can never be trusted to be precise.
I guess it wouldn't hurt to drive an LED with a few mA using the REF pin as the supply.
Last Edit: February 06, 2022, 11:08:51 am by xavier60
Logged
Hioki AS100D vom, HP 54645A dso, Fluke 87V dmm, AN8008 dmm, Agilent U8002A psu, FY6600 function gen, New! Brymen BM857S-(With Battery)
xavier60
Super Contributor
Country:
Reply #52 on:
February 06, 2022, 11:18:03 am »
There is a chance that the indicator BJT might never turn on enough. To fix it, a high value resistor might need to be connected from the REF pin to the Base of the indicator BJT.
Logged
audio
audio
Regular Contributor
Country:
Reply #53 on:
March 03, 2022, 04:38:03 pm »
Hi to all,
How this circuit is having control on Current?
R11 should be 240ohm or 120 ohm but in the circuit it is 4.7K. does this affect the q current of regulator.
what is the function of T1,T2,T3,D8,D9 in current regulation???
Last Edit: March 03, 2022, 05:26:50 pm by audio
Logged
Print
Search
Pages:
Prev
1
2
3
All
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
