Author Topic: how to understand the functionality of circuit  (Read 4664 times)
Offline audio
  • Country: in
Re: how to understand the functionality of circuit
« Reply #50 on: February 06, 2022, 08:27:48 am »
Sir,
Is there any way to include current limit indicator circuit. PFA.
Online xavier60
« Reply #51 on: February 06, 2022, 11:05:45 am »
One way is to use another BJT to sense the voltage between pins 2 and 3 with a resistor in series with the Base. The best resistor value might need to be found by testing. A 1K to start with.
The indication can never be trusted to be precise.
I guess it wouldn't hurt to drive an LED with a few mA using the REF pin as the supply.
« Last Edit: February 06, 2022, 11:08:51 am by xavier60 »
Hioki AS100D vom, HP 54645A dso, Fluke 87V dmm, AN8008 dmm, Agilent U8002A psu,  FY6600 function gen, New! Brymen BM857S-(With Battery)
Online xavier60
« Reply #52 on: February 06, 2022, 11:18:03 am »
There is a chance that the indicator BJT might never turn on enough. To fix it, a high value resistor might need to be connected from the REF pin to the Base of the indicator BJT.
The following users thanked this post: audio
Offline audio
  • Country: in
« Reply #53 on: March 03, 2022, 04:38:03 pm »
Hi to all,
           How this circuit is having control on Current????
                                  R11 should be 240ohm or 120 ohm but in the circuit it is 4.7K. does this affect the q current of regulator.
          what is the function of T1,T2,T3,D8,D9 in current regulation???
« Last Edit: March 03, 2022, 05:26:50 pm by audio »
