Hello all,
Currently I'm working with the TI chip
TUSB9261 trying to connect an MSATA drive to a computer over USB 3. I've modeled the board off
this reference design. I've attached schematics of my current implementation along with the reference design, however I'm having some very strange issues. Without the chip installed, the resistance between the 5v, 3v, 1.8v, and 1.1v rails to GND is all in 50k-1M ohm range, which makes sense considering all that should be connecting them is bulk capacitance. When I power the board without the chip mounted, the power supplies all behave normally, outputting the correct voltages.When I soldered the chip to my PCB, however, the resistance across the 1.1v to GND rail dropped to a steady ~420 ohms. When I connected the PCB to my computer, Windows detected it, but gave me a "device malfunctioned" error, and it quickly disconnects. This looped for a while, with the board connecting, "malfunctioning," then disconnecting. After a while, the board ceased connecting altogether, and I measured the resistance across the 1.1v rail, which was now close to ~20 ohms. I left the board overnight and measured the resistance across the rail again, at which point it has returned to ~420 ohms. Removing the chip from the PCB gets rid of the short altogether.
I'm not really sure what to make of all of this, or how to fix it. Does anyone have any ideas or advice?
