Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Solder mask question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solder mask question (Read 1319 times)
Dave Wave
Contributor
on:
July 30, 2013, 11:33:48 am »
So I got an xbox that had rrod.
I got a kit that change the heatsink mounting and fixed the problem.
The kit uses metal washers between the heatsink and the PCB.
The washers are slightly larger in dia than the pad around the hole on the pcb and comes very close to/covers a trace on the pcb.
I would assume that there is a solder mask covering the trace, preventing it from shorting out to the grounded heatsink.
How durable is the mask? Is this going to short out at some point do to the pressure of the washer?
Anybody care to chime in?
Thanks!
-Dave
Logged
digsys
Supporter
Country:
Re: Solder mask question
Reply #1 on:
July 30, 2013, 11:38:11 am »
With pressure and heat, there's a very good chance the washer will eventually "sink" through the mask,
after all, it was only a liquid when first applied. Definitely worth fixing !!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
