Author Topic: Help Needed: Using CAEN A5203 with A5255 Adapter and Single-Ended Function Gener  (Read 127 times)
Offline hasamsiddiqui@gamil.comTopic starter
I am a beginner in this field. Could anyone please guide me on how to operate the CAEN A5203 FPGA module with the A5255 adapter?
According to the manual, the A5203 with the A5255 requires an LVDS input signal. However, the function generator I currently have provides single-ended outputs.
My function generator has two output channels. Is it possible to use the two channels to generate a differential signal compatible with LVDS, or would I need a dedicated LVDS driver/converter between the function generator and the A5255?
Any guidance on the correct setup and connections would be greatly appreciated.
Offline voltsandjolts
