Author Topic: How to wire a Current Transformer  (Read 890 times)
Offline anishkgtTopic starter
  • Country: qa
    • George Hobby
« on: August 13, 2018, 05:22:04 am »
Hi All,
Is there anything else that i would need when using a Current Transformer ? I will be using this with an arduino to measure AC current of a Spot welder. The current schematic of the Current Transformer is from its data sheet (http://www.tamuracorp.com/clientuploads/pdfs/engineeringdocs/L06PXXXS05.pdf)
The optocoupler is to sense when the electrodes are shorted for a spot weld.
Offline Dave
  • Country: si
  • I like to measure things.
Re: How to wire a Current Transformer
« Reply #1 on: August 13, 2018, 06:20:27 pm »
That is not a current transformer, but rather a hall effect current sensor. Yes, your connection method is correct.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
The following users thanked this post: anishkgt
  • Country: qa
    • George Hobby
« Reply #2 on: August 16, 2018, 09:13:08 am »
Thank you appreciate it.
