Hello there,
Since the day when I began playing with BJTs, I understood that BJT beta = Ic/Ib, which is distinct from h_fe. Hfe is the value from the data sheet which is typical maximum current gain from that transistor in the common emitter configuration.
Beta is amongst other things, dependent on the configuration of the transistor.
When I know Q1 has a beta of 200, and I know the collector current is 6mA, base current must be 30u. Will somebody kindly confirm that this is correct? Due to recent event, I want to be sure that I have understood correctly.
Hope it isn't too much trouble.
Thank you for your time.
Kind regards,
Marius
