In terms of how a power supply is designed and functions.. no, there really isn't a difference. You can throw around buzzwords and price tags all you like, the power supplies for those servers work just like any other.
You were the one who posted the datacenter pics with the three-phase, weren't you?
No.
I'm sorry, for some reason, I thought you were the one who posted that.
When I said fancy features, I meant HPE Power Discovery Services (PDS) combines the HPE Intelligent Power Distribution Unit (iPDU) and HPE Flex Slot Platinum Plus power supplies with HPE Insight Control software to create an automated, energy-aware network between IT systems and facilities.
Some simple firmware and a lot of marketing speak. Nothing to do with how the input is handled.
What I mean is with a normal desktop PC, we generally break the AC down to 12VDC, 5VDC, 3.3VDC, and -12VDC. With servers like this one, we don't. Also the equipment inside is generally better (higher quality) and is meant to run 24x7, whereas a desktop PSU really isn't most of the time. Granted, there are some nice desktop PSUs that have higher quality capacitors and other components. Ripple current is a bad thing, we agree on that I'm guessing. With desktops, you can buy a cheap power supply that will kill your motherboard faster than shit because of ripple current. With these server ones, you don't have to worry about that so much. This PSU is "smart" in the sense that it's designed to be connected to a PDU that it communicates with. Generally, desktop power supplies are plugged into surge protectors, not PDUs and aren't designed to communicate with that surge protector.
In the end, yes, they do the same thing. They convert AC to DC.
I need true 240VAC 1-phase
Everyone can agree on this. And we can also all agree.. you have true 240VAC single-phase. It happens to have a centre tap making it split-phase distribution which is messing you (and the 'technicians' at HPE) up.
Whether we like it or not you need a 240-volt line to neutral power service.
No he doesn't. He needs a PDU capable of safely distributing his centre-tapped 240V phase, rather than a huge lump of iron hanging on his wall.
Okay, let's try looking at this at a different way, because I'm getting tired of just debating what I need versus how to actually hook up the transformer properly. How many companies make RAM? What? Three maybe? Or car batteries? We'll go with car batteries. There's two, maybe three companies that produce car batteries. But how many different car batteries can you purchase? I have no idea. But it's a lot more than three, I know that. There's die-hard, there's Duralast, there's NAPA, and a lot of those have different quality batteries as well, like NAPA Gold, or NAPA Silver, where Gold is supposed to be better.
I have a friend who worked in the automotive field for a long time and could give tours of one of the main manufacturers of the car batteries. When you walked in, there was a giant glass display with all the different batteries they produced. One of them was Duralast. They used to call Duralast Durablast because they're kinda garbage. This battery manufacturer made Duralast, but they also produced some really high quality batteries. So, if they're making high quality batteries, why are Duralast so cheap? It's because the company that's buying the Duralast is requesting that they don't use the high quality parts. They want them as cheap as they can get 'em, so they have the battery company make them as cheap as they can get them.
Same is true with RAM. Now, there's only a few companies who make RAM, even server RAM. We have 2400 MHz load reduced DDR4 dual rank RAM in our servers, made by HPE. It's pricey. So I came up with the brilliant idea of maybe instead of purchasing the pricey HPE RAM, I would go and maybe purchase the cheaper server RAM produced by another company. It'd work the same, probably be the same quality, just a different manufacturer. Now this is where the trouble comes in. Let's say I went ahead and purchased that other RAM and then all of a sudden, the motherboard's AC-DC converter circuit fries because of some manufacturing defect that has absolutely nothing to do with me. The server is still under warranty, I call them up, do they cover the warranty? No. Why? Because I wasn't running their "qualified" HPE RAM.
Even if HPE is wrong, and I can somehow power the PSUs with split-phase, they state that I need single-phase 240VAC. If something were to happen, they would use that as an excuse not warrant the server faster than you could blink an eye! I will say that today I got an invoice for one purchase that included some of the upgrades for one of the servers. It was over 10,000$. If I went and bought that stuff off of websites myself, it would have been over 30,000$. That's just the upgrades for the one server. I mention this for the sole reason that when HPE says we need 240VAC single-phase, I don't want to take any chances with them not covering their server's if something breaks because I didn't listen to their techs or went against what I was told to do.
This is not the first time HPE has said that we needed true 240VAC single-phase for the PSU's. When our account executive contacted his HPE technicians pre-sale, to get the power advisory started, we gave them a list of everything that was going to be in the server, they came back with what choices we had for PSU's, and the only one on the list where these 1400 watt ones and they made it very clear that we needed the 240VAC and it wouldn't work with our split-phase. We didn't like that, we asked if there wasn't any other options, why HPE didn't make a PSU for this server at 1400 watt that went to split-phase, we did conference calls, etc. In the end, they said most people purchasing these power supplies have 3-phase. Most commercial buildings don't have the residential wiring like we have. Like, I think it was IanB stated, most people aren't running a real data center out of their basement in a residential zoning district.
At this point, I'd rather not debate anymore on whether or not I can go against what HPE techs and the people I called last night said and continue going in circles with you saying I need to send the PDU back and buy one that works with my electric and me saying I need the transformer. That's not getting us anywhere. Even if you feel it's a waste of money, I feel it is the correct move, and all I wanted was advice on what transformer to purchase, and then how to properly wire it up. And yes, I am going to pay the licensed electrician lots of money to come watch me wire it up to make sure I don't make no mistakes. I'm going to send the sketch into the city, I'm going to get the permit, I want to purchase the equipment through my VAR because I can get it much cheaper than the electrician charges, I don't know if he'd be okay with that or not though, he hasn't called me back.
But safety wise, rest assured, I'm not ignorant enough to try doing this myself. I posted in the Beginners section because to me, this 240VAC 1-phase is new. I have no problems running 240VAC split-phase or installing breakers, or wiring an outlet and running the wires to the breaker, up to code and all that, but this is out of my league, and is the main reason I came here, to try and understand it a bit better.
I appreciate the input you've given me and you definitely got me thinking, that's for sure. I've learned a good bit since I started posting, which is wonderful, and for a bit, I enjoyed our debates, but now I just don't want to debate it anymore. Thanks.
