Author Topic: Looking for a miniature wire to wire connector  (Read 4013 times)
Offline zaptaTopic starter
« on: October 29, 2013, 01:08:19 am »
Hi all, I am looking for small quantities (~3 pairs) of small wire to wire connectors for 4-6 wires. This is for a one of application with tight space. I plan on using 30AWG teflon wires. Ideally the connectors will have small pitch but not too small so I can assemble it by hand, may consider 0.1" pitch but would prefer denser.
I looked around and could find many wire to board connectors but not wire to wire.  I am located in the US so prefers products I can purchase locally (e.g. digikey, mouse, etc). Price is not a big issue but need to be reasonable (let's say 5-10$ per pair).
Thanks,
Z.
Offline rexxar
    • Forever Tinkering
Re: Looking for a miniature wire to wire connector
« Reply #1 on: October 29, 2013, 02:17:35 am »
Have you looked at .05" headers? Like Mouser # 517-45206-600230
« Reply #2 on: October 29, 2013, 02:19:40 am »
This is a wire to board connector, right? I need wire to wire.
Offline edavid
« Reply #3 on: October 29, 2013, 02:40:48 am »
Would micro-USB be small enough?  You can buy extension cables and cut them in half.
Offline rexxar
    • Forever Tinkering
« Reply #4 on: October 29, 2013, 02:41:25 am »
Sorry, I misunderstood. Your best bet would probably be a circular connector, something like this.
Offline rexxar
    • Forever Tinkering
« Reply #5 on: October 29, 2013, 02:44:07 am »
I don't know if you could find micro USB cables with all five pins connected. If the shield isn't connected to the gound pin, though you could use that as a 5th contact.
Offline nanofrog
« Reply #6 on: October 29, 2013, 04:05:45 am »
There's a recent thread on this, and some of the info may be useful to you.  ;)
https://www.eevblog.com/forum/projects/looking-for-small-(ish)-wire-to-wire-connectors/msg307716/#msg307716
« Reply #7 on: October 29, 2013, 04:09:08 am »
I was thinking about it but the cable is too bulky.  http://www.ebay.com/bhp/micro-usb-extension
« Reply #8 on: October 29, 2013, 04:15:32 am »
Thanks. Very useful indeed. I need some time to process it.
Edit: I looked at the Molex site and it seems that this one:
http://www.molex.com/molex/products/datasheet.jsp?part=active/0701070004_CRIMP_HOUSINGS.xml
And one of these:
http://www.molex.com/molex/products/datasheet.jsp?part=active/0050579305_CRIMP_HOUSINGS.xml  // polarized
http://www.molex.com/molex/products/datasheet.jsp?part=active/0050579405_CRIMP_HOUSINGS.xml  // polarized and locking
Will do the job. I will give it a try. Thanks everybody for your help.
« Last Edit: October 29, 2013, 04:47:43 am by zapta »
« Reply #9 on: November 09, 2013, 06:12:46 pm »
A quick followup, Per one of the suggestions I used  digikey WM2536-ND + WM9137CT-ND  and  WM2903-ND    + WM9139CT-ND and was happy with the results. I did not have a compatible crimp tool so used short nose pliers and a soldering iron.
