sigh.. so all we have so far is the belitteling of people that have no math or physics understanding (the usual 'talking down'on people, and 'look at us we have a degree')
But none have given an explanation on how it works...
-edit- while i was typing this up even more 'fuzz' was added...
here we go : (without the math, QED
bullshit overload )
There are two types of material :
N material is a smiconductor that has an excess of free electons
P material is a semiconductor that has a shortage of electrons ( sometimes explained as 'an excess of holes'. in reality there are no 'holes' , ony lack of electrons )
N and P material are constructed by 'seeding' ( the technical process is called implantation ) a donor material into the silicon ( or germanium or other semiconductor ). Silicon has 4 electrons on its outer shell but would really want to have 8.. so it readily forms bonds with other silicon atoms. We can create a 'free electron' by injecting a donor material that has 5 electrons on its outer shell ( like Boron. the silicon will combine with the Boron and 'share electrons'. this fifth electron is now 'free'. It is still bound by atomic forces to the phosphorous but it is also highly mobile : it can be 'knocked off easily' that is why we call it free.
We can also create bonds with an element that has only 3 electrons on its outer shell , like phosphorous. Here the semiconductor will bond and have a link with 7 electrons ( 4 of its own and 3 donors from the implanted material. So it is one short from an ideal state, but it is happier than ith only 4.
The material that is one electron short is P material ( there is a missing electron or a 'hole' there to fit one in )
The material that has an excess of electrons is N material.
Right , now that we know this we can take a look at the transistor structure.
The classic bipolar transistor is a 3 layer structure of N and P material. The denotation NPN and PNP tell you how the layers are ordered.
Lets take a look at an NPN stack.
Before we delve in in :
the properties of a conductor material is that electrons can flow freely. if all electrons are trapped you have an isolator.
So we stack a bit of n material on top of P material on top of another bit of N material. And then magic happens.
At the intersection of these mateirals the free electrons fomr the N material combine with the free 'holes' of the P material and you get actually a thin region where all free electrons have fallen in a hole. ( this is called the depletion layer ) and no further electrons can cross this barrier.
In schematic form
NNNNDPPDNNNN
NNNNDPPDNNNN
NNNNDPPDNNNN
N = n material full of free electrons
D = depletion zone : n material free electrons have fallen in p material holes
P = p material 'short of electrons
So what happened here is that , free electrons form N regions have fallen in 'holes' in the P region . This has trapped them and created two depletion layers. Since the electrons are trapped you have effectively created an isolator there. The reason this forms only a thin layer is simple : as electrons combine with holes the 'pressure' decreases. Let me see how i can explain this one:
We know that like charges repel each other and dislike charges attract each other. So , in an area where you have an excess of electrons , they are all trying to push each other away. if you give them a path to escape they will go that direction. So here is this one side that touches the P material full of nice holes they can fall into : and away they go. They happely move that way , fall in a hole and get trapped. The electrons behind them can still skip over because the ones behind those are still pushing. But eventually the depletion zone is wide enough , and enough electrons have been removed from the n region that the reminaing electrons have not enough 'push' to keep this process going and it stops. It stops , provided we do not apply an external source of pressure.
And this is what we will do : I am going to apply an 'electron source' to the right hand terminal to give a bit more 'pressure' . An electron source is the negative terminal of a power supply as electrons carry negative charge.
To close the loop i will apply the positive terminal of the same supply to the P material.
NNNNDPPDNNNN
==NNNNDPPDNNNN================
NNNNDPPDNNNN ||
=======(+)source(-)======
so , by feeding more electrons into the right hand terminal i create more 'pressure' and current will begin flowing ( the arrow above shows the way they flow). I am pulling the electrons out the P material region.
For clarity sake , lets slap a name on these terminals shall we ? Since the element i connected my 'electron source' to is 'emitting' them, i shall call this terminal the emitter. pretty logical.
The terminal i am pulling the electrons from i shall call... the base. No, not the collector.... got you there ! I will explain later why this is the 'base'.
So , by sending electrons in the emitter , and pulling them out of the base i create an electron flow. This is the base-emitter current ( in electron flow the emitter-base current, but a it was not known electrons were negative in the olden days we assumed current flows positive to negative... )
Right. Now i will attach another power source. A source that will feed even more electons in to the emitter but , this time, will attempt to pull them out of the third terminal. The 'collector' terminal , as this is where we will tempt to collect them.
================(+)source(-)=====
|| NNNNDPPDNNNN ||
==NNNNDPPDNNNN==================O
NNNNDPPDNNNN ||
If i am not pulling anything out of the base i have those two darned depletion layers in the way that prevent current from flowing. if i start pulling some electrons out of the base the depletion area is being broken down (remember the depletion area is the area where no movement is possible because there is 'pressure' balance... ) and the electrons start flowing.
if i start pulling harder and harder i can move the depletion areas so much that they almost touch each other. In the mean time , my other 'power source ( the one between collector and emittor) has been wicking away electrons from the collector region ( in rest there is a surplus of electrons there. Because we 'doped' this material duering construction remember ? )
so we come to a point that electrons are being wicked from emitter into base , and they get so close to an area where there is even a bigger 'void' of electrons ( the collector is more positive than the base. More positive means less electrons avaialble , or more holes ) so electrons that were destined to go into the base actually start flowing into the collector region where they are whisked away by the power suource there. And there you have the transistor function.
The harder you pull on that base , the more electrons you pull out of the emittor. if they come close enough to the collector area they are attracted there becasue there is an even bigger 'void' of electrons there. so , by 'steering' the flow in the base you steer the flow in the collector. Amplification !
So the base current actually moves these 'zones' until they touch and then celectrons start flowing from emitter to collector. if i stop pulling there the depletion areas move inside the structure and the flow stops.
Now, there is more than meets the eye. This trickery only works under certain contitions.
That right hand terminal ( the emitter ) is actually heavily seeded with electrons.
The base is only mildly made void of electrons the collector is also only mildly seeded.
So there is more 'pressure' in the emitter than in the collector.
This base layer is also very very thin compared to the other two.
This helps the electron run into the collector as there is only so much that can flow into the base ( there are not enough holes there for all of them to fit as it is only mildly seeded with holes )
And since the collector area is only mildly seeded this area is very fast depleted by the higher positive voltage applied there. So the electron coming out of the emitter can go 2 ways : into the base or into the collector. ( remember the collector is beeing sucked 'dry' by the applied power supply . a suply that is at a higher level than the level at the base) and they take the path of least 'resistance' : the path where there are the most missing. in essence that collector 'N' region actually becomes a 'p' region while the transistor has current flowing through it.
This is your very very basic operating of a bipolar transistor. To make a PNP redo this explanation but swap 'electrons' with 'holes' and swap 'positive' with negative.
Now , on the subject of this 'base' terminal. Here's where that comes from.
The first transistor was not made out of N and P material. You can actually make a depletion area between a doped semiconductor and a metal. you don't need tow doped semiconductors. Actually the word semiconductor is used to denote an element where you can change the conductivity of. it can be isolating , or it can be conducting , dpeending on what you do with it. a metal is always conducting. an isolator alwasy iolating ( unless you 'force' charge across with extremely high voltages (voltage = pressure ))
But metal can be an electron donor.. tis is actually the principle behind a shottky diode. a classic diode is an N and P region where as a schottky diode uses only an N region and a strip of metal.
the first transisotr was a strip of P material that was laid on top of a copper plate. this strip of p material formed thus the 'base' of the transistor construction. And there you have it : the 'base'
the emittor and collector were made by putting a strip of gold foil on a triangular piece of glass. this piece of glass was pressed down with a screw onto the base. the pressure of the sharp edge did two things : it cut the goild foil in hlf and pressed the extremities into the germanium 'base' (they used gemranium at the time )
the strip of gold 'feeding' electrons was the 'emitter' , the strip collecting them the 'collector'
collector-- ---- emitter
base ___\ /____
and this is also where the transistor symbol comes from... the line is the base and you have two electrodes under a 45 degree angle ( they used a 90 degree corner of glass , put that under 45 degrees and pressed down , snipping the gold foil in half and creating the two depletion regions of gold-germanium )
I scavenged two links from the internet that show this first transistor ( replica's )
This one below is high resolution. You see at the bottom a slab of copper , on top of that the slab of germanium and then the triangular piece of glass with the gold foil on edge ( they metallized the glass so they could solder it to that 'wavy bit' whch is actually a spring pressing the glass down on the germanium slab.
http://www.porticus.org/bell/images/transistor1.jpgWe use the arrow to indicate where the emitter sits.
Now , that first transisotr worked both ways. there wa sno difference between emitter and collector apart form where they applied the correct polarity. This came only later as tey sought to improve performance. that is where they started making the assymetrically shaped construction of having a heavily doped emittor and a weakly doped collector. but that is another story ...
So there you have it : the transistor in simple terms , without requiring a degree in maths and physics. You can of course now slap on the maths and start calculating the field strengths and electron levels and all the other stuff , and figure out what is the optimum layer thickness, implantation strength but that is just a numerical representation of what is happening.
Electrons are very simple elements that never went to school and don't know anything about maths or physics. They repel each other and if they see an area where there is 'room' they simply go that way.
No doubt there are going to be people that will start complaining about quantum effects and other things. The above explanation is according to the 'electron model'. A Model that is understandable without 'fuzz'. If you think you can do better , please feel free to write a posting here with a more accurate model.
