Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
How use salvaged transformer to make a variable dual bench power supply????
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How use salvaged transformer to make a variable dual bench power supply???? (Read 1371 times)
Dhanushka
Regular Contributor
Country:
on:
October 01, 2019, 07:20:57 am »
Dear all,
I salvaged a transformer from an old Sony stereo audio system. It has 2 x 12 V/2 A (center tapped) and 2 x 20 V/3 A (center tapped) outputs. These wingdings are isolated for the continuity testing. But when I measure the voltage they had relative measurements. However, I use two lines of 12 V as an 24 V input to a variable lab power supply module. (
https://www.aliexpress.com/i/32769033201.html
) Also, one 20 V output as a input to another power supply module to make dual output power supply. But when I made this I could not make dual power input to a circuit combining the as two separate power supplies. (positive of one is connected to negative of another) When I connect these two, current limiting indicator glows. The negative lines has a voltage drop of about 4 V. Please tell me how use this multi output transformer to make a dual variable output power supply?
Logged
xavier60
Super Contributor
Country:
Re: How use salvaged transformer to make a variable dual bench power supply????
Reply #1 on:
October 01, 2019, 07:35:36 am »
That should work. With the power off, do you find any continuity between the output terminals of one module to the other?
Also check between the windings again. Maybe there is something on that transformer connection PCB.
Last Edit: October 01, 2019, 08:02:58 am by xavier60
Logged
HP 54645A dso, Fluke 87V dmm, Agilent U8002A psu, FY6600 function gen, Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Dhanushka
tautech
Super Contributor
Country:
Taupaki Technologies Ltd. Siglent Distributor NZ.
Reply #2 on:
October 01, 2019, 10:01:15 pm »
Transformer winding phasing is most likely wrong.
Disconnect prior to the rectifiers and experiment with secondary connections using a bulb that will indicate glow when phasing is wrong.
Logged
Avid
Rabid
Hobbyist.
tunk
Super Contributor
Country:
Reply #3 on:
October 01, 2019, 10:11:37 pm »
The heatsink in the front of the photo looks a bit small - what's the max current will you draw from that one?
You may also want to add a fan at the back, and ventilation holes at the sides.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
