Author Topic: How using Gotek SRF1M44_DU26  (Read 779 times)
Offline madaoTopic starter
« on: November 23, 2019, 08:56:25 pm »
Hello
I have here a  Gotek  SRF1M44-DU26, a  Floppy emulator, slimline-variants.
I owned 2 Gotek SRF1M44-U100 (Standard),  it works fine. Selfformat-function runs fine (2 button pressing and switched unit on,  it make  1000 drive into one USB Stick )
DU26-Variant is much other, has not  self-format-function, but read  1Gb  (FAT32 formatted) Stick without problem.
But  this shitty piece crap is too stupid to writing file into  USB Stick.  IT  write and  file is  preset. But if i plug  USB stick out, this file is away.  pressing of button doesn't save file to  stick. Only one success by  over 30 fail. (Stick  from U100-devices is also used)
How wrong do i with him ? Or it is just a money-waste ?
It is for Tek TDS754C (in future  TDS754D )
regards
matt
« Last Edit: November 23, 2019, 08:58:30 pm by madao »
Re: How using Gotek SRF1M44_DU26
« Reply #1 on: December 05, 2019, 07:19:23 pm »
Solved
