Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Which Hakko tip is best for smd work please? Hakko FX-888D
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Which Hakko tip is best for smd work please? Hakko FX-888D (Read 2161 times)
HobGoblyn
Supporter
Country:
on:
January 15, 2020, 08:11:48 pm »
I have the Hakko FX-888D soldering station, can someone recommend a chisel style tip suitable for 0603 work please?
(I have a hot air station too)
Many thanks
Logged
rstofer
Super Contributor
Country:
Re: Which Hakko tip is best for smd work please? Hakko FX-888D
Reply #1 on:
January 15, 2020, 09:06:32 pm »
I use an 1/8" chisel for everything. I usually try to stay with 0805 but I wouldn't have any problem with smaller packages. Maybe a 1/16" chisel would be nice but I get along without changing tips.
Research "drag soldering" for packages with many pins.
For 0805, I sometimes use solder paste on the pad, place the part and hit the intersection with the soldering tip.
Flux is the answer to soldering SMDs. I sometimes just run a bead of flux around the pins, put a blob of solder on the tip and touch the joint.
Get some SolderWick of various sizes. I will sometimes get solder bridges on fine pitch packages. I put some flux in the neighborhood and slurp up the excess solder with SolderWick.
Logged
HobGoblyn
HobGoblyn
Supporter
Country:
Reply #2 on:
January 15, 2020, 09:16:09 pm »
Many thanks, I'm in the process of setting up my first lab (another thread on here somewhere) and thanks to other posters advice, have equipped myself with MG Chemicals solder wick in 5 sizes, 423 - 427, Going from 0.03" to 0.125" (0.8mm - 3.1mm).
Logged
james_s
Super Contributor
Country:
Reply #3 on:
January 15, 2020, 11:04:15 pm »
I also use a 1/8" chisel tip for everything, my go-to parts are 0603. You want some decent pointy angled tweezers and ideally small diameter solder. The most common mistake I see people making is using way too much solder.
Logged
HobGoblyn
rstofer
Super Contributor
Country:
Reply #4 on:
January 16, 2020, 12:47:01 am »
Tweezers like these:
https://www.sparkfun.com/products/10602
Logged
HobGoblyn
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
