You're welcome.
The ripple current will depend on several factors: The output impedance of the PSU, the amount of output voltage ripple of the PSU and the load current you are drawing. It may be that they just feel that there needs to be more bulk capacitance on the output than they can comfortably fit inside the PSU package for best noise performance, or may be required for stability of regulation. As the manufacturer doesn't seem to have made any specific recommendation for ESR then I suspect that it is the former and not critical.
The markings you quote on the capacitor look to be manufacturer specific, family for instance, if you check the manufacturer's website, the datasheet ought to say. For the X2 classification, you should see a bunch of standard logos (VDE, UL, SA etc.).
