Author Topic: what is the most relevant programming language for ee?  (Read 14634 times)
Re: what is the most relevant programming language for ee?
« Reply #100 on: November 06, 2018, 10:55:55 am »
Yes.
Just a hilarious reference here: http://www.stroustrup.com/1995_Java_whitepaper.pdf
Note the domain.
Online brucehoult
« Reply #101 on: November 06, 2018, 11:02:14 am »
>Nothing in the example code that comes with Arduino or on the Arduino or Wiring examples web sites uses:
So what?
I probably should quit while i am ahead since "So what?" sinks that argument, but....
You are utterly and absolutely sure that no third party library ANYWHERE uses Templates or Multiple Inheritance?    I am sorry but that is the sort of semantic hair splitting that comes when you engage in a religious argument.   The arduino IDE uses and supports C++.    The claim that no embedded project uses C++ is just nonsense.    The one feature of C++ that tends NOT to be implemented on MCUs is new/delete and that is simply because many mcus lack a proper memory controller.
Say what? Your post was already well into "wrong" and "either didn't read or didn't understand what I wrote" territory. But this isn't even wrong.
New&delete (along with the underlying malloc&free, which they are just a type-safe wrapper around) have *nothing whatsoever* to do with a memory controller, proper or otherwise.
Your other posts have since established you as a nutter so I'm not going to reply further to you.
Offline Howardlong
« Reply #102 on: November 06, 2018, 12:16:06 pm »
I tend to agree, we've been using malloc/free and similar long before integrated memory controllers or even MMUs became a thing, let alone ubiquitous. Think of all those DOS real mode applications, including Windows 3.x in real mode, so in effect anything that ran on the original PC and PC/XT.
« Last Edit: November 06, 2018, 01:05:02 pm by bd139 »
Offline bsfeechannel
« Reply #104 on: November 06, 2018, 01:04:18 pm »
>Every time you say C++ you give C free publicity.
Please don't feed the trolls :-)
love
Crazy Pete
I thought YOU were trolling. That's why my sarcastic reply. However, if you're really serious about your concepts, you have a lot to learn.
Just for the record. I learned C. Then I learned C++. I had absolutely no difficulty with C++ because of that. I encourage everyone to learn both languages. In whatever order they like.
C and C++ are different languages, created in different circumstances for different purposes in different times. In common, both are great and influential. Each in its own way.
And religion is a (fascinating) object of study of science that involves archaeology, geography, history, sociology, psychology, anthropology, philosophy, political science, linguistics, semiotics, etc.
