After replacing the aborted F3, the 3325A passes the 3 tests without errors. I approached the calibration, at least in amplitude, excluding harmonics and spurious, not having an SA. I performed the D / A Converter Offset, up to punyto "e", after which I was unable to continue, point "f" I cannot execute it, at this point the explanation is not very clear.
