You might try downloading the HP 3325B service manual. That has the missing page, although the potentiometer numbering might be slightly different between the A and B models. Between the 3325's procedure description and the 3325A's schematics, you should be able to figure out what to do.
If I remember, the power supply is adjusted with one pot to -15V as measured at a test point.
