Author Topic: Measure reversible voltage without PD drop?  (Read 3017 times)
Offline 12407622Topic starter
Re: Measure reversible voltage without PD drop?
« Reply #25 on: August 14, 2019, 11:06:50 am »
Well, that worked out much easier than had been anticipated:
https://youtu.be/1_PeoERrCLw
12407622  ;D
Offline ledtester
« Reply #26 on: August 14, 2019, 06:40:50 pm »
Can you post a schematic of what you eventually went with?
Thanks - and congratulations on getting it working!
« Reply #27 on: August 15, 2019, 12:55:08 am »
Hi ledtester,
Boring old germanium diode bridge wired across the motor terminals, 10K pot from +output of that to gnd, with very tiny greencap (3mm x 8mm x 2mm) and 4V7 clamp zener from wiper output to gnd.
The running motor is disabled for 2ms, each 1/12th of a second, after which period the back EMF from 2 successive measurements is averaged.
Yet to be properly tuned PID does the rest. A small Kp, much larger Ki, and almost none, but some very small Kd.
Sorry, a diagram would be just scribble, as I'm still recovering from an 'accident' with the hard drive I kept all those type of programs on. I hope the description was clear enough for anyone to follow.
Thanks very much for your interest, and fabo suggestions, everyone.  :)
12407622
« Reply #28 on: August 22, 2019, 08:34:23 am »
A little larger smoothing capacitor added for better noise immunity, and a stop on collision facility added.
https://youtu.be/doWnCFVbF9Y
Circuit attached:
T.  :)
