I took apart a 1990s FAX machine, some nice parts I can re-use/add to the collection. I'm having a hard time finding any schematics or repair threads on them, just google ads basically. Found 1 similar Panasonic manual tho.
At the front end of the machine there's about a 30cm/11" row of 29 SMD LED's, I thought they would be for lighting a page through, to read it. But I don't see anything 30cm/11" that would read it.
I don't see anything optical at all that size that could read what's on a page. Doesn't all fax machine have the ability to insert a page and copy/send it ?
I guess I only remember seeing fax machines in Die Hard 1/2
And how does the thermAL PRINTER WORK ? I found a 24cm/10" bar with what I guess is the heater element, it has a 15pin serial connector.
How does that work so that it can burn how ever many pixels wide 10" is ?
