Hi, it's me, the noob who knows enough to be dangerous
I've read a lot of literature on the human body acting as a 50mhz monopole antenna (in fact depending on posture between 40 and 60 i believe).
There's even an old (10 years +) US patent by the DOD on using this as a means to not only track individuals behind walls, but even identify if they carry a metal object (possibly, in this case, a weapon).
My question is as follow: since nowadays pseudo radars such as the RCWL-0516 are available for around a dollar each, why haven't we seen the implementation, or at least the development of full scale indoor tracking, especially as part of open source projects?
In other words, imagine placing such device at 5 yards/meters interval in a grid pattern on a floor (you probably need to add some sort of directional component to them, such as placing them on a rotating servo and track the azimuth) connect them all to a server, run the system for a few minutes with NO humans on the floor, then let humans in, and spot the difference
- Why isn't it trivial to then derive a heat map from the interference patterns aggregated on the server, a bit like we do on a daily basis when running netspot-like wifi surveys?
I feel like i'm missing the obvious - because there are hundreds if not thousands of papers on the matter of presence monitoring and human tracking (including leveraging mimo multipathing/time of flight analysis on off-the-shelf wireless routers), but I have yet to see a single commercial application or even a proof of concept video on youtube.
Thank you for illuminating me on the matter if possible at all!
