Author Topic: HV (500v) Voltage monitoring relay circuit help  (Read 4244 times)
Offline andybarrett1Topic starter
« on: October 14, 2016, 11:05:39 am »
Hi all
Thank you for reading.... I am looking to build a device as simple as possible that will indicate that a 500v AC line has decayed to a safe level (< 10v maybe) so as we can safely swap out test equipment.
At first was thinking of a mains fail relay but it is only interested in 15% drop on the lines
Same with an Opto isolator / relay of some description.
Then got to thinking about op-amps in some configuration but again starting to over complicate things.
Has any body had any need for this sort of application or similar to reiterate as simple as possible  :-+
Thank you for reading  :-//
Andy
Offline Gyro
Re: HV (500v) Voltage monitoring relay circuit help
« Reply #1 on: October 14, 2016, 01:08:50 pm »
If you think that opamps are getting a bit too complicated then you could always try the humble 555 timer. It gives you two comparators, a reference resistor chain, a flip-flop (with reset) and a reasonably strong output stage.
It ought to be possible to come up with something, using resistive dividers obviously. It's a shame it's an AC source, as you would need to rectify and (minimally) smooth the input first. You would also need something in the 5-12V range to power the 555 / relay.
Just a thought anyway.
P.S. You could maybe also use it in re-triggerable monostable mode to detect the loss of AC zero-crossings. It's unusual to have an AC signal with a decay time - if it's an AC supply then it's normally either there or not.
« Last Edit: October 14, 2016, 01:18:40 pm by Gyro »
Best Regards, Chris
Offline oldway
« Reply #2 on: October 14, 2016, 07:07:13 pm »
A relay with 230Vac coil as FINDER 55 series with 2 MOV's (varistor's) type S20K175 EPCOS in // with coil This must be feeded by a power resistor 15K 11W in serie with the 500Vac.
Offline Seekonk
« Reply #3 on: October 14, 2016, 10:24:31 pm »
We built a commercial product that did this and it was antipolar diodes into an opamp.  A LM431 makes a great relay driver, combination volt reference - opamp - and driver.  Just use a high resistance voltage divider to get the 10V detect and protect input with diodes.  Detecting only half cycle should be sufficient.
« Reply #4 on: October 19, 2016, 01:37:29 pm »
Hi all
Thanks for all the replies...
Seekonk .... Would love to know a little more about your design if possible.
BR
Andy
Offline max_torque
    • bitdynamics
« Reply #5 on: October 19, 2016, 07:32:32 pm »
Most commercial testers consider over around 50volts to be "dangerous".  So you need a device to indicate the bus is less than 50v, perhaps with a little leeway, say under 40vdc.  My suggestion is a simple LED, driven through a power resistor and zener to delay the switch on a bit.
For fail safer, fit two such devices and include a checking procedure in our operational notes (ie ensure both leds are lit when bus IS greater than 50v)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #6 on: October 19, 2016, 07:42:52 pm »
Use something like this to power a small signal relay. With sufficient heatsink and parts you can create an 500V capable linear regulator.  :-+
TL431 can be replaced by a zener. You get the idea, right?
You'll need to get rid of ~10 watt perhaps. Negligible :P compared to the complexity of the alternatives.
You can mount it on this.
Source:
http://myelectrons.com/mosfet-tl431-ldo-linear-voltage-regulator/
« Last Edit: October 19, 2016, 07:48:53 pm by Jeroen3 »
Offline R005T3r
« Reply #7 on: October 19, 2016, 08:37:29 pm »
if you don't feel comfortable with 500V lines and you don't want to messing around making your own PCB circuit , you need a minimum voltage relay. Something like this one:
They are not cheap, but you can set options such as the delay time and a precise range of voltages to operate with it. For 500VAC, if the relay can't handle the voltage or current, you can cascade the output with a suited relay, if you are in a 3-phase environment you need a "contactor" or power relay. Also, I wanted to mention that "safe voltages" are from  0 up to 49V max in AC at 50Hz (which in my country are required to be used by law in industrial applications and signaling).
This solution is probably the simplest and safest:  3 relays and you are good to go and that particular relay is guaranteed it will work.  Another simpler option could be a rotary switch: they ensure at least 4mm of space from the live contacts and yep that's why rotary switches are used: to ensure that it's not live or goes live in any way unless the rotary switch is used, for safety reasons, NEVER use breakers for sectioning a circuit: they do  not provide a sufficient safe distance between the switch contacts, because they are designed to break the circuit if something malfunction.
Offline julian1
« Reply #8 on: October 19, 2016, 09:34:25 pm »
Why is there a decay time - measurable in seconds/minutes/hours? There must be some other engineering principles in play - since my first reaction is that the only thing I would trust at that voltage is a multimeter and a (secondary) mechanical isolation switch on the unit.
« Reply #9 on: October 21, 2016, 09:00:37 am »
Hi Julian
Decay time maybe in Seconds.... There because of the presence of some large LC Filters on the lines...
BR
Andy
Thank you for all other Ideas and suggestions all ..... Liking the use of the shunt regulator at the moment !
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #10 on: October 21, 2016, 09:36:26 am »
Don't forget the 20mm varistors. It'll catastrophically fail if you surge it too much.  :-BROKE
Meanwhile, why don't you comply to safety regulations and install an isolator switch.
Offline WackyGerman
« Reply #11 on: October 21, 2016, 09:42:33 am »
The easiest way is just to put in a voltmeter in parallel to the source . As an option you can put in an indication lamp that lights when voltage is present as a second safety feature if the voltmeter fails
