Author Topic: Please I need help to calculate resistance?  (Read 2764 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
Re: Please I need help to calculate resistance?
« Reply #25 on: January 21, 2021, 05:03:28 pm »
If you should find the most neutral way to adjust the volume and balance, what technique / component would you take a look at?
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Online Ian.M
« Reply #26 on: January 21, 2021, 05:23:21 pm »
First define 'neutral'!  If you are looking for an audiophile grade solution, I'd consider a pair of R-2R multiplying DACs built from gold plated contact reed relays and precision non-inductive resistors, controlled by a MCU that returns to a clock stopped deep sleep mode (to avoid it contributing any digital noise) once it has made any attenuation change until it is woken up again by further user input.  For audiophools,ditch the MCU and control the relays from pair of concentric rotary switches  via a diode matrix that 'programs' the attenuation steps.  For the rest of us, the best digitally controlled volume/balance chip we can afford is probably a better choice!
« Reply #27 on: January 21, 2021, 07:15:20 pm »
LOL sounds interesting, but it sounds to me like you didn't write English in 90% of the text:-)
Or in short, have no idea on what it means:-)
EDIT: my original idea was also to separate the control unit from the audio, so I could use cheap standard parts while only a single component did touch the sound.
« Last Edit: January 21, 2021, 07:18:41 pm by FriedMule »
