I'm not sure, but it may be that low current output you measured is the result of module just checking if the bulb is not broken. Like a car computer does that, when you turn on ignition. It gives low current to all bulbs to check continuity. In that case it is not a failure. Also it rises a question, just how sofisticated is this module? Maybe it does not work correct because it is sensing some fault?
