Author Topic: I am looking for an RS422 Device?  (Read 1748 times)
Offline jwhitmoreTopic starter
  • Software head strays into the Hardware.
« on: April 11, 2017, 09:18:57 pm »
Hello all, the subject sort of sums it up but I may well have missed that boat. I'm playing with/learning about RS232, RS422 and RS485 and would like to interface with devices using all of them. RS232 and RS485 as I already have devices that talk using those physical interfaces. RS422 however seems to have slipped away. A search on eBay will throw up any number of interface devices which will convert an RS422 device to USB or whatever but nothing seems to actually use it. I guess given it's a bit more complicated then the other two nobody uses it for simple temp sensors or whatever.
I guess I could create two ends of an RS422 interface with a PCB design but both ends could be wrong and I'd never know. If I had something which I was fairly confident was communicating properly and I could communicate with it I'd feel happier.
Any thoughts or let it go? I assume that there's a load of 422 legacy kit still used in industry?
Offline Paul Moir
Re: I am looking for an RS422 Device?
« Reply #1 on: April 11, 2017, 09:31:01 pm »
RS422 has the same signalling as RS485, just without the ability to have multiple transmitters.  Think if it as RS-232 with RS-485 signalling.  So you just use a RS-485 driver for it.
(Minor note:  RS-422 allows for multiple receivers.)
EDIT:  That's somewhat wrong:  they are slightly different in signalling, but I think transceivers use the spec overlap.
« Last Edit: April 11, 2017, 09:39:18 pm by Paul Moir »
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #2 on: April 11, 2017, 09:49:35 pm »
...and is often implemented as 4-wire full duplex (effectively balanced RS-232)
Don't ask a question if you aren't willing to listen to the answer.
Offline NW27
« Reply #3 on: April 12, 2017, 03:09:06 am »
RS422 can also have multiple transmitters and receivers.
The significant difference between RS422 and RS485 is RS422 uses four wires (2 for tx and 2 for rx) and is full duplex ie it can receive at the same time that it is transmitting.
RS485 uses 2 wires only and is therefore half duplex.
You can use RS485 chips to create a RS422 network. As an example of the PC end, set one RS485 chip as a constant transmitter (output enable is a separate thing) and the second RS485 chip (again still at the PC end) as a constant receiver.
This gives the four RS422 wires at the PC end.
Do similar for the remote end.
Also the lines should be terminated and preferably pulled to a known state
Sent from my SM-N920I using Tapatalk
Offline hendorog
« Reply #4 on: April 12, 2017, 06:04:01 am »
Worth noting as well that you can connect  RS422 device(s) to RS485 device(s) - obviously this means the network, and the 422 devices, need to operate half-duplex.
« Last Edit: April 12, 2017, 06:16:25 am by hendorog »
« Reply #5 on: April 13, 2017, 07:55:00 pm »
Thanks for all the advice it's probably not the best solution but I've laid out a board with 2 x SN65HVD72D chips. I can use one of the for half duplex RS485 and use both for full duplex if I find something to talk to.
