Hi Avelino Sampaio,
Power supplies look easy but are definitely not.
The schematic you're talking about dates back at least 10 years, when those fancy modern opamps weren't available.
The ADA4077 is a beautiful opamp and the 1.2V/uSec is certainly fast enough for a good LAB power supply.
You do need a fast and good Power section if you use the ADA4077 as shown in my schematic.
The reason I started experimenting with the ADA4077 is because in the first datasheet that came out a much wider phase margin was mentioned...
But of course I could not really stick to that, because on that datasheet it said "provisional".
In the end, the fast Power section showed in my schematic gives a good performance.
This just as I indicated to you, that this also with an LM324 opamp posible with a good fast power section. :-)
It doesn't always make sense to figure everything out optimally, you also have to take your application into account.
I got the nicest and most wideband low Ri of my design with 2x the 2SA1943 + 2SC2911 and then with two low inductance resistors for the current sense resistors(0.1 Ohm), short wiring and tuned output network direct over output connectors of the power supply.
For an impression of how good that power section can be, below is a picture of the impedance measurement.
"F" is the double compound power section, with 2x 2SA1943 and de filter in de picture.
The output impedance is certainly a magnitude better than I have been able to find from other LAB power supplies.
However, very good types have come out in recent years from some IC manufacturers with very low noise and wideband low Ri.
But of course those are not LAB power supplies.
In a private email to Avelino Sampaio I had already explained that that very nice low Ri that is possible with my design, disappears like snow in the sun due to long and/or bad cabling!
Why then still design it so that the Ri is very low....
You can as example then e.g. connect multiple loads to the power supply without them affecting each other.
So it really depends on your application and how well you are going to make it.
Not to mention, it also depends on your knowledge and measurement equipment and measurement setup how well you're going to get it.
The optimal result is pretty hard to get right.
You can compare it a bit to building a good 10V Voltage Reference, pretty simple in schematic, but oh so hard to keep it within 1PPM between 20 and 30 Celsius and load variations.
Some tips for the builders of linear power supplies.2N3055 type power transistors are too slow.
Most old types Darlingtons are too slow.
These above type transistors cause the phase margin to become too small for a relative fast responding current and voltage loop.
One then often solves this by e.g. making the currrent loop much too slow, don't do that!
Use good and not China junk power transistors.
And certainly they can make good components in China, but through ebay and aliexpress this is almost impossible to find them.
Use good Motorola audio transistors (if you can still get them original) like the MJ21193 - PNP MJ21194 - NPN series.
These have a Ft of around 7-Mhz.
This makes the internal cabling in the power supply less critical for oscilations.
The 2SC5200/2SA1943 are of course also good(Fairchild and On Semi make them with differetnt parnumbers),
but because of their high Ft they can give problems, usually this can be solved by a capacitor at the input of the power section that compensates the impedance of the longer wiring to the buffer capacitor.
Most of the Sanken power transistor you can also use.
If you can order at Mouser or another company, look at the NJL1302DG and th NJL3281DG these ar "Thermaltrek" power transistors from ON-Semi.
These transistors have an extra diode in the housing intended for temperature sensing of audio amplifiers.
For power supplies you can use them for driving the fan control.
Short side jumpI use these transistors (four pieces) to heat an oven and the diodes drive the opamp for the temperature control, which works very well!
ConclusionEspecially for beginners, it is better not to try to get the most out of it.
Use medium speed power transistors and as I have already shown you can make a very good power supply with a NE5534A (YES! the "A" type) that is low noise and fast enough to respond.
With the advantage that you can then also compensate the opamp as needed.
I use at least five different types of power supplies, one sites fits all is not really possible.
When building a linear power supply, you can learn a lot.
Remember that every piece of wire has resistance and inductance.
So also on the wires of the capacitors, or the wires that are e.g. on induction low resistors.
You will notice this for example when you start connecting the sens wires and the network that comes over the terminals of the power supply.
This is not of course incomplete, but keeping it reasonably legible is for is hard enough for this "Dyslexic Monky" <= Thats Me! *Grin*
Kind regards,
Bram
