Author Topic: Could someone please tell me what this part is?  (Read 678 times)
Offline cpposteveTopic starter
« on: October 07, 2021, 03:02:56 pm »
Hi all. Please see attached picture. Only markings are ST ELECTRONICS. and CBN Z440. Trying to work out what this part is so I can see if this is the issue my JBC soldering station. Thanks
Offline Manul
  • Country: lt
Re: Could someone please tell me what this part is?
« Reply #1 on: October 07, 2021, 03:27:22 pm »
The following users thanked this post: cpposteve
Offline Andy Watson
« Reply #2 on: October 07, 2021, 03:32:11 pm »
Possibly SMBJ36CA - bi directional 36V transient supressor.
https://www.st.com/resource/en/datasheet/smbj.pdf
« Reply #3 on: October 07, 2021, 03:37:32 pm »
Yes that would make sense. I’m guessing it’s used so if it sees a spike of anything over 40v in this case is shorts and absorbs the spike in voltage? Is this what they are used for? If so is it correct that it’s open circuit untill it goes over that thresh hold voltage? Thanks
Offline Manul
  • Country: lt
« Reply #4 on: October 07, 2021, 03:52:03 pm »
Yes, that is correct. Open circuit with some small capacitance and leakage.
Offline mayor
« Reply #5 on: October 09, 2021, 11:04:47 am »
Check out the topic around here about the smd markings database: https://smd.yooneed.one/
CBN	3KSMC58CATG	Fagor Electronica
DO-214AB Transient voltage supressor
CBN LN61CC5102M Shanghai Natlinear Electronics
SOT-23 Voltage detector IC
CBN LN61CC5102N Shanghai Natlinear Electronics
SOT-343R Voltage detector IC
CBN LN61CC5102P Shanghai Natlinear Electronics
SOT-89 Voltage detector IC
CBN RP106N101D5 Ricoh
SOT-23-5 Linear voltage regulator IC
CBN SMCJ16 Galaxy Semiconductor
CBN UM1550B-39 Union Semiconductor
SOT-89 Linear voltage regulator IC
CBN XC6116B021MR Torex Semiconductor
SOT-25 Voltage detector IC
The following users thanked this post: cpposteve, farlander762
