Author Topic: AVR atmega32a EEPROM question  (Read 1936 times)
Offline CalebMcNevinTopic starter
« on: April 18, 2013, 02:30:56 am »
does anyone know if it's possible to accidentally overwrite your program by saving data to EEPROM on an AVR microcontroller? I'm planning on generating random numbers by giving an arbitrary seed on my first power up, then using the last random number generated before power down as the new seed for the following cycles, and I don't want to screw my program up by overwriting part of it. Or am I just completely off? Is the program even in the EEPROM? :p
Thanks :D
Caleb
Offline TerminalJack505
Re: AVR atmega32a EEPROM question
« Reply #1 on: April 18, 2013, 02:35:46 am »
The program is in flash memory not EEPROM so you will be fine.
« Reply #2 on: April 18, 2013, 02:59:00 am »
I guess my noob is showing  :-[
lol, thanks! :D
Online Psi
« Reply #3 on: April 18, 2013, 12:09:59 pm »
Don't forget to program the EESAVE fuse bit if you want to preserve EEPROM data between reprograms.
(By default the EEPROM data is erased everytime you reprogram the flash)
