Author Topic: SMPS - Why there is ringing on secondary ?  (Read 493 times)
Offline MacIntoshCZTopic starter
  • Country: cz
« on: November 22, 2023, 04:18:47 pm »
Hello,
Can someone explain why there is ringing on secondary side (before caps)? Its loaded with aprox. 30R Halogen lamps  on 100V at the moment. Its fullbridge converter 100V/40A. I even tried to simulate this and its also in simulations, RC snubbers removed high frequency ringing but this 1,1Mhz remains.
Also it rings only when voltage is rising. Qp1 probe is marked as 1 in schematic, QP2 probe is marked as 2.
Switching frequency is aprox 50Khz, tl494 driver. I think it should look like that, i just dont understand why.
Thanks for help
Offline boB
    • my work www
Re: SMPS - Why there is ringing on secondary ?
« Reply #1 on: November 22, 2023, 04:47:18 pm »
From first glance, looks pretty much normal for a discontinuous mode inductor.
Usually from parasitic L-C  and not enough load.  Parasitics here are really small values except for the inductor.
Typically, just some ringing that doesn't over-voltage any components are fine and don't need to be dealt with.
Bring that 100K load R  down to where it is always drawing some current and the ringing should delay or go away.
boB
« Last Edit: November 22, 2023, 04:52:32 pm by boB »
K7IQ
The following users thanked this post: MacIntoshCZ
Offline radiolistener
  • Country: ua
« Reply #2 on: November 22, 2023, 04:58:18 pm »
it happens due to impedance mismatch between secondary coil and load on high frequency.
  • Country: cz
« Reply #3 on: November 22, 2023, 05:08:35 pm »
Yes, i forgot to mention that this ringing goes away with higher loads.
Ok  :-+ :-+ :-+, I had readen in somo books that when medium has different characteristic impedance, than wave reflections happens. But how exactly this works right there i dont know  :-//
« Last Edit: November 22, 2023, 05:13:51 pm by MacIntoshCZ »
