I've noticed a lot of even small projects that use USB or PSUs with MCUs have a PTC fuse in them, and until a few weeks ago I didn't even know that existed. I read up on them, but that didn't really help me understand how they work - the details just provided me more questions than I had before. I am hoping that someone here may be able to ELI5 or similar so I get the idea.
Here's what I've done so far - I found some 0ZCJ0050FF2G "PTC RESET FUSE 8V 500MA 1206" while I was getting some other stuff at DigiKey and added a few of them to "try them out". I understand that they're rated to handle a given "hold current" (actually a given power rating) and once the temperature rises high enough (
https://www.belfuse.com/resources/datasheets/circuitprotection/ds-cp-0zcj-series.pdf says above 125 degree C - my Flir tells me it's about 80 Degree C on the surface) the resistance goes up to "virtually remove the current". Well, that's not what I'm seeing - all the "response time" parameters I see doesn't show up in my little test-setup.
I connected the unit to a bench PSU, providing it with 5V - since the 8V is maximum power. Added a DC load to control the power usage and a voltmeter to show the voltage drop over the PTZ. Unfortunately the 500mA is based on 8V so 800mA would be the limit with 5V if I understand this right. Nothing happens (changes) at 800mA - I need to get close to 1100mA before the temperature slowly gets to the point where the fuse "sets". But according to the datasheet they're talking sub-seconds ... perhaps I'm reading that wrong, it's absolutely a very slow moving train here. Or do I need to surge with almost 1A for the trigger to be fast? At that point my components will definitely be fried.
The voltage drop is about 0.3-0.5v (pretty high for a 5V circuit) which jumps to 4.7v when the fuse sets. This means there's still current going through the circuit even when the fuse "pops". Not sure how that protects the circuit? It takes a while for the fuse to pop, by then damage may already have been done and worse, there's still power going to the units post "pop". And I seem to only be able to reset by turning off power to let the PTC cool down - even lowing the current consumption to 100mA seems to keep the high temperature fairly steady.
So I'm not sure I understand the "fuse" part. Power is still flowing even when this unit pops, so why is it a good design choice to have one (that's my presumption as I keep finding these everywhere). It seems to be extremely slow reacting and would depend on the type of PCB, thickness and what may be close to the PTC on the PCB? Let's say I have a design I know will not survive more than 500mA at 9v, how do I pick the right PTC? If I expect the average load to be around 200mA but it will peak just below 500mA during use for small periods of time. Since I didn't see the temperature go down significant when the current got low, it doesn't seem picking a 250mA "hold current' unit is the right thing? But if I pick at 500mA it will go WAY above 500mA before the PTC reacts, and that's definitely not a good thing. So help me understand the use case and how to pick the right value?
Perhaps this is more an ESD thing than a general input power protection?
