Author Topic: Constant current sink driver voltage dropping  (Read 1941 times)
Offline Rihards VeipsTopic starter
  • Country: lv
« on: November 07, 2017, 07:46:46 pm »
Hello
I am working on a led thing with a constant current LED sink PWM driver.
The LEDs I am using are common anode RGB leds.
The max R voltage is 2V
The max G/B voltage is 3V
The LED power supply is 3V but I need the red led to run at 2V
My LED driver max current is set to 20mA
Can I use a 50 ohm resistor between R and one of the driver outputs to get 2V on the LED instead of 3V?
I got the 50ohm value by using this equation:
R = (Vs - Vled) / Iled
50 = (3 - 2) / 0.02
This is what the schematic would look like including the driver output:
I don't have much experience with this LED driver stuff so I wanted to ask this here before I make my pcb for the project.
Thanks.
- Le Nub
Offline grifftech
    • youtube channel
Re: Constant current sink driver voltage dropping
« Reply #1 on: November 07, 2017, 07:58:26 pm »
Hello
50 = (3 - 2) / 0.02
Thanks.
Driver has current limit, no need for resistor.
  • Country: lv
« Reply #2 on: November 07, 2017, 08:10:50 pm »
Wouldn't I have to use the resistor to prevent the LED from burning out because of the 3V supply voltage? The max rating for the red led is 2V
- Le Nub
Offline kalel
« Reply #3 on: November 07, 2017, 08:28:44 pm »
From what I understand, if you have a driver that sets constant current, it should limit the current that the LEDs receive. That means you might need no resistor, if the current limit is set properly and works properly for the purpose. I don't know if there are some limiters that do need an extra resistor.
If you had a constant voltage supply, you would need a current limiting resistor to ensure that the LED doesn't get more than the rated current. This is because if the voltage is even slightly increased after some point, the LED will draw a lot of current, possibly burning itself out (guaranteed at some voltage).
Offline Damianos
  • Country: gr
« Reply #4 on: November 08, 2017, 10:27:43 pm »
A circuit of constant-current will regulate the current to the load. The voltage drop on the load will be what corresponds to the value of current. The rest of the voltage, of the power source, will be present at the terminals of the driver. So, a resistance there will prevent the driver to work properly. The problem is with the other two LED lights specified for 3 V, which is equal to the supply voltage; how the driver will adjust the current? Don't forget that the voltage is the force to move charge, current is the result of this movement...
Offline Audioguru
« Reply #5 on: November 09, 2017, 01:17:05 am »
Your schematic does not show constant current drivers.
Your LEDs driven from Mosfets with NO CURRENT LIMITING except the 50 ohm resistor to the red LED.
LEDs set their own voltage. You just need to feed a higher voltage then limit the current.
Nobody makes a 2V red LED, they have a range of voltages from maybe 1.7V to maybe 2.2V (look on the detailed datasheet) and you get whatever is available. If your supply is 3.0V and your LED is 1.7V then the 50 ohm resistor limits the current to (3V - 1.7V)/50 ohms= 26mA which is pretty high but the maximum allowed current is probably 30mA. If your supply is 3V and the LED is 2.2V then its current with the 50 ohm resistor is 16mA.
A modern bright green and blue LED has a voltage range of from maybe 2.8V to maybe 3.6V so many will not work from only 3V, and they also need a resistor to limit the current.
The following users thanked this post: kalel
Offline kalel
« Reply #6 on: November 09, 2017, 02:58:12 am »
I heard this before, but will they really not work at 3v? Or just not work at optimal brightness.
Offline mikerj
« Reply #7 on: November 09, 2017, 11:40:24 am »
Depends on the forward voltage of the LED.  Attached are the IV curves for some typical LEDs.  Note that with 3v on the green LED, you will only get about 2mA, and because you only just above the threshold voltage the current will vary significantly with temperature.
