Author Topic: Heart rate counter without microcontroller  (Read 3769 times)
Offline MrOmnosTopic starter
  • Country: np
  • BE in Electronics and Communication
« on: May 15, 2016, 03:05:05 pm »
Hi, I have made heart rate monitors before. I used Arduino, IR sensors and emitter and a amplifier to display a heartrate from the finger tips of a person on a seven segment diplay. Is there anyway to implement is without using a micro controller? I know how to do the sensing (using IR sensor) and signal conditioning. I want to display the heartrate on 2x 7 segment display.
Offline jeroen79
Re: Heart rate counter without microcontroller
« Reply #1 on: May 15, 2016, 03:50:24 pm »
You can build one from individual TTL or CMOS chips.
Just a few stages of decade counters that count the heart beats.
Then every minute you put the output in a buffer for the display and reset the counters.
Why do you want to do it without a microcontroller?
  • Country: np
« Reply #2 on: May 15, 2016, 04:37:38 pm »
Seems like too much trouble. If I were make something like a " led VU meter" you have in audio equipment so that with every heart beat a set of Leds would light up from down to up. How would I implement that without using a micro-controller.
Something like this but simpler
Offline aurmer
  • Insert text here.
« Reply #3 on: May 15, 2016, 04:46:28 pm »
Here is my crack at it. I don't know many advanced circuit designs, but a rudimentary design might look like this.
Sensor
Array of bandpass filters (your monitor's accuracy will depend on the filter count and resolution)
Each bandpass output feeds to a smoothing filter to get a measurable amplitude (voltage) for each freq range
Logic circuit which compares the filter outputs (voltage) and identifies the strongest voltage (aka the freq range which the heart rate falls into).
Output of logic circuit is a quantized voltage specific to the heart rate measured. An ADC will "decode" this output voltage giving you the bits you need to drive the display.
The ADC output is run through gate logic to convert to display segment bits.
This avoids programmable controller chips, but after thinking it through, it seems a bit convoluted, no?
Unless this is just a thought experiment in "how could it be done without a ?C", I would say this is exactly why microcontrollers were created, and excluding it from design is like building a skyscraper without steel.
If I just asked the wrong question, shame on me for asking before I was ready for help. Please be kind and direct me to a resource which will teach me the question I SHOULD be asking. Thank you.
Offline rstofer
« Reply #4 on: May 15, 2016, 04:50:18 pm »
That's easy!  Easier with a microcontroller but easy nevertheless.
You just build a tachometer circuit but with much longer time constants.  Every time you get a pulse, you dump some charge in a capacitor.  Usually this is done with a one-shot firing at every pulse so that the added charge for each pulse is constant.  The charge drains off the capacitor at some rate determined by a resistor.  In the end, a faster heart rate adds more charge than the resistor drains and the capacitor voltage increases.  The rest is just details.  Analog bargraphs should be pretty easy to find.
And, no, I wouldn't do it this way.  But, in theory, it should work.
Offline mav_iqdirect
« Reply #5 on: May 17, 2016, 11:39:26 am »
You may build some kind of opamp integrator plus VU-meter if you like. Adjust the integration constant and you'r done!
Offline alanb
« Reply #6 on: May 18, 2016, 01:13:30 pm »
What is the downside of using a micro controller that you are trying to avoid?
Micro controllers are not just Arduino's. Arduinos include functionality that you may not need and a physical size that may be greater that you desire. You could use a Microcontroller such as a Pic or Atmel without the additional support circuitry that is included in the Arduino.
Offline Seekonk
« Reply #7 on: May 18, 2016, 08:01:17 pm »
Considering I have a few tubes sticking out of me right now, I am interested in building one.  Interesting that half the monitors here won't read 150 or more beats per minute. Need something to check me at camp.  Honestly I can't feel the difference.
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #8 on: May 22, 2016, 03:33:18 pm »
how about using multimeter's frequency count function paired up with logic circuitry that feeds your heart rate to it?
you could also use ir led and photo diode
connect ir led to battery and photo diode to long scantime oscilloscope
make the ir led and photo diode face each other with your finger interrupting them
