Hey Guys,
I'm putting together a kit headphone amp and have a quick question regarding the power supply. Info on the PCB calls for a max input of 20VAC. The power supply I have is 15VAC 1.5 amp and states output voltage will be higher if less than this rated current is being drawn.
I'm unsure of exactly how much this little amp will draw but I'm expecting nowhere near 1.5 amps, more likely 1 / 10th of that. What I'm unsure of how much variance in output voltage to expect from the power supply, and if I should get another one.
Thanks!
